Ga door naar hoofdinhoud
Dit is de pagina met reparatiehandleidingen en Probleemoplossing voor de Sony PS2 Slimline (SCPH-750xx). Het Sony PlayStation 2 Slimline-computersysteem is een kleine, slanke en netwerkgereed spelconsole.
Disc Not Spinning Despite Fix
Hello, so just to sum this up:
I bought a PS2 from a charity shop that said it had a disc issue so I thought id just replace the disc drive, not a hard fix and a great bargain for £20
Ive changed the laser originally, didn't fix it, changed the whole assembly (the whole unit with the wires, thread bit to move the laser etc) still didn't fix it
So I bought a new unit altogether this time and still nothing, I'm assuming its something board related, so my question is
Firstly, what else can I do to fix this, and secondly if it is a board issue, where do I go about buying one? I've spent absolutely days researching now and I cant seem to sort it, any help is greatly appreciated as this PS2 is intended on being used for quite a while now
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@jakeax3d we would really need to know what your board number is. Even better post some good pictures of the main board and let's see what it looks like. For now, I would check the connector for the optical drive (step 22 of this PlayStation 2 Demontage ) See if you even have power going to your drive. Pin 2 is ground and pin 17 is VCC. After that I would check to see if the spindle motor gets power. Let us know what you find out. Voeg afbeeldingen toe aan een bestaande vraag
PlayStation 2 Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Was dit antwoord nuttig?
Score 1
9 opmerkingen:
Hey, thanks for that, I'll try to get the photos for you tomorrow morning, but the one in the teardown you sent unfortunately isn't the correct one, I forgot there were 2 models, I have the one where the lid opens upwards rather than the tray coming out
door
@jakeax3d sounds good. Let's see if we can get the Beast back to work again....;-)
door
@oldturkey03 do you know by any chance where I can just buy a replacement board etc?
door
@jakeax3d what board is? Remember there are a few different variations :-)
door
@oldturkey03 to be honest im not sure, all i know is its a ps2 slim
door
4 commentaren meer tonen
A disc drive is specific for other models, check yours and check your disc drive if it's compatible. And if don't order compatible one. If you have any questions feel free to ask
Score 1
1 Opmerking:
i forgot to mention, i accidentally said disc drive when I meant disc tray, its the one that lifts up from rather than comes out
door
Voeg je antwoord toe
Jake (AX3D) zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 328
