Ga door naar hoofdinhoud
The Dell Inspiron 7306 is a 2-in-1 manufactured by Dell. Specs: Inspiron 7306 2-in-1, 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz Processor, 16 GB DDR4 RAM 512GB NVME SSD (not replaceable)
2 Vragen Bekijk alle
Motherboard Crashed after tech “attempted” to diagnose.
Long story short, my laptop was losing its charge. After getting it diagnosed, I was told it was at the end of its life. If it doesn’t turn on, is it still possible to retrieve its stored data? TIA
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi @jalenahood, there are some ways you can try.
Ideally if the computer is able to boot up to windows,
I would suggest to check and backup bitlocker keys.
https://www.dell.com/support/manuals/en-...
Based on the battery replacement guide, on step 5,
i can see the there is nvme ssd.
Dell Inspiron 7306 P125 Battery Replacement
you can consider getting this usb enclosure
https://www.amazon.sg/ORICO-M-2-Enclosur...
Was dit antwoord nuttig?
2 opmerkingen:
I tried a battery replacement. It no longer turns on. After the replacement it slowly lost its charge and plugging it in does nothing.
door
@jalena
try disconnecting the battery from the laptop and power on the laptop with just the power adapter.
does it works?
door
Voeg je antwoord toe
Jalena zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 18
