Ga door naar hoofdinhoud
A 15.6" NoteBook from Gateway released in 2010.
11 Vragen Bekijk alle
Why is my Wi-Fi not turning on
I press Fn+ F2 and my Wi-Fi will Not come on. My laptop is stuck in WAN mode dialing a connection. My laptop worked fine until a couple of weeks ago and now NO Wi-Fi just Broadband.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Is your wifi network LED on? If so, and wifi doesn't connect to your router, did you power cycle your router & modem?
Have you processed the steps on page 123-125 in your manual?
If so, then you probably have a hardware failure. Your LT may have a replaceable WiFi card. It would be under one of the removable panels on the bottom. If so, you may be able to find a replacement.
A 14 yo LT may not be economical to repair.
Was dit antwoord nuttig?
Voeg je antwoord toe
Kisha Carter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 10
