Ga door naar hoofdinhoud
On 11 June 2014, Nissan unveiled the third generation Navara (now known as the NP300 Navara) and is codenamed D23. The D23 will not be available in the US.
My air conditioner is not working
Why is my air conditioner not working
Is dit een goede vraag?
Score -1
1 Opmerking:
1. car not running
2. broken drive belt
3. bad clutch
4. broken wiring
5. bad switch
6. refrigerant leaked out
7. air director not working or stuck
8. bad compressor
9. plugged up refrigerant lines
You need to see an HVAC mechanic.
door
Voeg een opmerking toe
1 Antwoord
Generally the first thing to check is the refrigerant pressure, the best way is to test it is via an OBD tool, the second thing is the AC clutch that engages the compressor, you can hear it when you turn on the AC but it works only if the there's a refrigerant to begin with.
So check if you have enough pressure inside the circuit.
Was dit antwoord nuttig?
Voeg je antwoord toe
Melissa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 23
