Ga door naar hoofdinhoud
The Dell OptiPlex 7010 MT is an office-oriented desktop PC. It comes with a third-gen quad-core Intel i5 or i7 CPU. It has 4 DIMM slots, 10 USB ports, two hard drive bays, and two DVD drive bays.
13 Vragen Bekijk alle
No display fan spinning
Ram is ok, lithium battery ok, cpu unchecked, power supply unchecked, it gives no display not even bios
Is dit een goede vraag?
Score 1
4 opmerkingen
Does it show any lights on the front or emit any beeps when you attempt to power it up?
door
i removed cmos battery (lithium) and it still is spinning fan and no display
door
@formulet
Did you remove the power from the PSU and also press the power on/off button as well, after removing the cmos battery, as suggested?
door
@jayeff yes (idk if i can send a video but i will if i can)
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @formulet
I realize that you said that the lithium battery is OK but try a power refresh in case the BIOS has become corrupted and is preventing a normal start i.e the PC is not passing POST (Power On Self Test)
Here’s the procedure:
a). Disconnect the power from the PSU
b). Open the PC and remove the coin cell RTC battery from the motherboard. Here’s the owner manual for the PC that will help. Go to p.13 to view the procedure to remove the coin cell battery.
c). Press and hold the PC Power On/Off button for a full 30 seconds and then release. This will restore the BIOS back to the factory default settings.
d). Reinsert the coin cell battery .
e). Reassemble the PC and reconnect the power to the PSU and check if it starts OK. There may be a message on the screen about the date and time being incorrect. This is normal as the BIOS has been reset. Once the date and time have been corrected, the message won’t appear the next time that it is started.
Was dit antwoord nuttig?
Score 2
8 opmerkingen:
i did what you said 1). moniter is ok with the cord 2). it works even without bios (the same fan spinning no display)
door
@formulet
What is the Power LED showing - see p.55 of the owner manual linked above?
door
@jayeff amber off white steady
door
@jayeff idk if it helps but last time it was working i change the os
door
@formulet
What OS did you install?
Disconnect the HDD from the motherboard and try to get into BIOS
door
3 commentaren meer tonen
Voeg je antwoord toe
Formulet zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 90
