Ga door naar hoofdinhoud
De Miyoo Mini is een open-source handheld-console die op 2 december 2021 door Miyoo op de markt werd gebracht. De Miyoo Mini is uiterst compact, zodat u hem altijd en overal in uw zak kunt steken of eruit kunt halen. De basisprijs is 269,00 Chinese yuan.
Why is my screen black
i believe i miss up my miyoo mini it was in miyoo ui and i put a onoin os sd card with an update it install but the screen turn black it turns on i can here sounds still just i can see anything I tried putting the old sd car with ui in it nothing i turned it off and turn it off and on still nothing I know it is dumb but i didnt know this would happen. you think it is fix able
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
This is most likely an software issue.. So if I'm correct, it failed after you've tried to install a firmware update for this device?
If this is the case, the best thing to do is to contact Miyoo. You could replace the motherboard to fix it, but this will be expensive.
Hopefully Miyoo do have something to re-flash the device so that it can be used again instead of replacing the motherboard....
If you are wondering regarding the motherboard replacement, here is a video: https://www.youtube.com/watch?v=6R2h4kfW...
Please let us know how it goes!
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
This is for the miyoo mini plushic i have the regular small one wh is the miyoo mini not the plus but thank you for your help
door
Hi! My pleasure! Is this the video for your model? https://www.youtube.com/watch?v=97kOOxP3...
Have a nice day!
door
Voeg je antwoord toe
Flux zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 1,081
