Why don’t my car has no spark
Why is my car as no spark
Is dit een goede vraag?
Krijg snel toegang tot handleidingen, onderdelen en antwoorden voor jouw apparaten
This vehicle had a recall on the Cam Position Sensor. Which typically throws a 0340 DTC Code and will prevent spark at the plugs. I would start with pulling the codes from the computer and verifying that your car is not part of the original recall and never got serviced otherwise my first inclination is that it is the crank position sensor which is known to cause this issue.
I hope this helps out a bit.
Cheers!!
Moe
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 58
Have you tried to replace the battery?
door Hampter
