Ga door naar hoofdinhoud
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 Vragen Bekijk alle
Why don’t my car has no spark
Why is my car as no spark
Is dit een goede vraag?
1 Opmerking:
Have you tried to replace the battery?
door
Voeg een opmerking toe
1 Antwoord
This vehicle had a recall on the Cam Position Sensor. Which typically throws a 0340 DTC Code and will prevent spark at the plugs. I would start with pulling the codes from the computer and verifying that your car is not part of the original recall and never got serviced otherwise my first inclination is that it is the crank position sensor which is known to cause this issue.
I hope this helps out a bit.
Cheers!!
Moe
Was dit antwoord nuttig?
Voeg je antwoord toe
Bryan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 58
