Ga door naar hoofdinhoud
How do I replace the keyboard?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @douglasmensen
Here's the hardware maintenance manual taken from this support webpage for the laptop.
To replace the keyboard/top cover assembly, you will have to completely disassemble the laptop. Start at p.40.
On p.71 you will find the HP part numbers for all the keyboard/top cover assemblies that can be used in the laptop.
The keyboards are country specific so you need to work out which part number to use for your model.
Search online for the part number only appropriate to your particular model variant, too find suppliers that suit you best. usually the part number is located somewhere on the underside to the cover, if you wish to verify before ordering a replacement.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Douglas Mensen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 85
Altijd: 1,120
