Ga door naar hoofdinhoud
The Asus Q524U is a 2 in 1 laptop/tablet convertible.
Can it be repasted?
My processor is constantly running at 100% and my laptop is getting very hot very quickly. I know Asus isn’t know for using good thermal compound and I’ve also had this laptop for around 7 years so either way, it’s due. Does it use standard thermal paste or something else like thermal pads?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @beardysteve
Looking at the image in Step.16 of the ifixit Asus Q524U Motherboard Replacement guide, both the CPU and the GPU appear to have residues of have thermal paste on them.
Here's the ifixit Aanbrengen van koelpasta guide that may help.
Electronics Skills Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
5 - 20 minutes
Asus Q524U Motherboard Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
10 - 25 minutes
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
That’s kind of what I thought. I just didn’t want to take my laptop apart without making sure lol
Thank you!!
door
@beardysteve
You may also have to check why the CPU is constantly running at 100% as this is unusual.
Go to Task Manager → Processes → CPU and check which process is causing the CPU to be operating at this level.
To get to Task Manager right click on the Taskbar.
If you meant the CPU fan then as you said the thermal paste may need refreshing
door
Voeg je antwoord toe
beardy_steve zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 53
