Ga door naar hoofdinhoud
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
20 Vragen Bekijk alle
How is the battery hatch door replaced?
The flip door over the batteries and memory has been damaged. I have a new door, but it came with no directions. I need to know how to remove the old door and install the new door.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The door is held to the front assembly via a small round pin. you will have to use a very small pindriver (a small nail might just work too) and some needle nose pliers to remove it. Watch the small spring that is in the middle of the hinge. A bit tedious and it does require some good eyesight and dexterity. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
It does not appear to be enough room to use the pin driver.
door
Voeg je antwoord toe
Sherri C zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,178
