Ga door naar hoofdinhoud
Een 250 GB 3,5" SATA-harde schijf uitgebracht door Western Digital.
Hdd is not getting detected
When i turn on the pc harddisk turns on and then turns off after 10-15 seconds. I want to recover my data from that disk. I tried to contact manufacturers of that disk but they say that disk is a copy and not a genuine one. I also tried to connect that drive to other pc but there also not getting detected
What should i do ?
That data is very much important to me. Please help
Is dit een goede vraag?
Score 10
1 Opmerking
I have already recovered some HD's by removing the electronic board and resoldering it with the hot air rework station.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@khushaldhumane explain to us what this means "they say that disk is a copy". There are two possible failures, The controller board or the mechanical part. If it is mechanical, you want to leave your hands off and send your drive for data recovery to a place that specialize in this. Those are not cheap.
For the controller issue, you could try to replace the controller board. I've done that a few times and successfully removed data from those drives. But, you will need to get the right board etc. Not always an easy find. Check this guide for what I am referring too,
Hitachi GST Deskstar HDS721010CLA332 Harde schijf-controller vervangen
If you need more info or guidance, post some good pictures of your board etc. with your Question. that way we can see what you see.
Voeg afbeeldingen toe aan een bestaande vraag
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Hitachi GST Deskstar HDS721010CLA332 Hard Drive Controller Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
20 minutes
Was dit antwoord nuttig?
Score 2
I am also stuck in the almost same situation. In this case, put your HDD in the sun for around 1 hour, then let it cool down for 10 minutes, and then insert it. In some cases, the HDD is fully recovered, and in some cases, it shows up in your PC for around 5-6 hours or a day. I recovered my data with this method.
Voeg je antwoord toe
Khushal Dhumane zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 131
Altijd: 3,838
