Ga door naar hoofdinhoud
Doesn't boot but the fan comes on at high speed
I bought a rebuilt Dell off of eBay, loaded basic software (WinXPpro, Lab view), and transferred files from an old comp. All seemed fine. Computer sat idle for about 6 months and now won't start but fan is on steroids. I went on Google and tried various fixes (rebooting, unplug things, remove/reseat RAM) no change. I looked around at the transistors (?) and some could be showing less than flat surfaces but I'm far rom qualified to make that call. is there any hope?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@brian34791 let's see what your motherboard looks like. We need to see what you are referring to as transistors. Post a picture of your motherboard etc. with your question. That way we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag
Alos, clarify this "unplug things". Let us know what kind off things you unplugged. Let us know which fan is on steroids. I assume you are referring to the CPU fan. That could be because of bad/failed sensors.
Next download the user guide for your computer from here and let us know what your computers form factor is.
Try to enter the BIOS. Unplug your computer. Remove one or even two RAM modules and/or disconnect the HDD. Then plug your computer in and try to turn it on. Restart the computer, press F2 while the Dell logo is on the screen. Let us know what happens.
is there any hope? H E double hockey stick, yes! Let's keep the vintage equipment going. It might take some work and some research but I am pretty optimistic with this.
While you work on your computer, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Brian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 84
