Ga door naar hoofdinhoud
A consumer grade netbook released by HP in 2009.
Power switch fail to stay on
Why won’t my power switch stay on ? It turns on for a few seconds
Is dit een goede vraag?
Score 1
2 opmerkingen
Hi @stevetodd,
Does it stay on when the charger is connected to the laptop?
door
No, alls I hear is the fan running and then it stops trying to start-up.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I will try to answer your questions based on descriptions above.
This model especially netbook there are some problems after a few years usage.
It won't stay on when some short happen to your motherboard, so better for you to bring it to the closest repair shop to know more about the hardware diagnostics. Little bit complicated to explain here.
Was dit antwoord nuttig?
Score 1
Hi @stevetodd
Try a full power refresh and check if that resolves the problem.
a). Disconnect the charger from the laptop (if connected) and then remove the main battery from the laptop.
b). Open the laptop and disconnect the RTC coin cell battery¹ from the motherboard.
Here's the maintenance and service guide for the laptop. Go to p.36 and p.44 to view the procedure to remove/replace the main battery and the RTC coin cell battery, respectively.
c). Press and hold the laptop's Power button for a full 30 seconds and then release it.
d). Reconnect the RTC battery, reassemble the laptop, reinsert the main battery and connect the charger.
e). Check if it turns on OK.
If it does then there may be a message stating that the time and date are incorrect. This is normal as the BIOS has been reset back to its factory default state by the above procedure. Once the date and time have been corrected, the message won't appear the next time the laptop is started. Also any user definable BIOS settings that were changed by you to suit whatever operating requirements you needed, will have to be change back again.
¹ When the RTC coin cell battery is disconnected/removed from the laptop, measure its voltage. If it is <2.5V DC replace it. Search online for 537616-001 to find suppliers that suit you best. If you don't have a DMM (digital multimeter) to measure the battery voltage then if the battery is >5 years old, replace it anyway. This battery is used to maintain the BIOS settings once the laptop has been turned off and what happens is that when its voltage gets low the BIOS can become corrupted, preventing the laptop from operating normally.
Score 1
Voeg je antwoord toe
Steve Todd zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 153
