Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie en aanvullende informatie voor de GE Refrigerator GFE26JGM****, een koelkast met automatische ontdooiing zonder ijsmachine of dispenser in de deur, voor het eerst beschikbaar in 2019. Deze pagina bevat informatie voor modelnummers die overeenkomen met het patroon GFE26JGM****.
Wiring connector assembly help
Removed the doors, while disconnecting the harness, the connector came off. The color of the wires don't match. We need help matching the wires back up
Black/yellow, white, 2 white/blue
Black yellow, white, red/white, gray/white
Update (05/05/23)
Afbeelding
Afbeelding
Update (05/05/23)
  • trying again
Afbeelding
Afbeelding
Update (05/05/23)
GFE26JGMWFBB is the model
Is dit een goede vraag?
Score 1
3 opmerkingen
can you add photos
door Deel
@dougwilds i can't see them doug it just says image
door Deel
@dougwilds pictures can only be added to Question or Answers , not comments. It's fixed :-)
What make and model is this?
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi @dougwilds
I can't find the mini manual (GE part #31-1000533) for a GFE26JGMWFBB but there are two models which are very close, i.e. GFE26JGMAFBB & GFE26JGMNFBB.
Unfortunately they have different mini manual part numbers not only from your model but from each other as well. Maybe there are slight variations in the wiring due to them having different features perhaps
At least they show the connections and colours of all of the wires used
GFE26JGMAFBB (31-1000396)
GFE26JGMNFBB (31-1000474)
Using an Ohmmeter, you may have to identify the wires by colour back to the main board connector pins, by looking at either of the manuals to see if one is appropropriate.
Hopefully one will be and then once you know where they connect to on the mainboard, use that manual to see where they go to and what colour wire they connect to or end up as.
Hopefully this is of some help.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Doug Wilds zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 640
