Ga door naar hoofdinhoud
Reparatie-informatie en handleidingen voor de Apple iPhone 5c die op 10 september 2013 werd aangekondigd. Model: A1532, A1456
thermal paste under battery?
Afbeelding
well, i used a heat gun on this phone to remove the battery... and i notice something sliver under the battery... and the adhesive tab didn't budge (and ended up ripping)
Afbeelding
Afbeelding
yeah it was kinda hard to see, but still is this normal...?
is this just the base but damaged?
edit its not... it crumbles when you get something under it.. could it maybe be thermal paste....?
Is dit een goede vraag?
Score 1
26 opmerkingen
There shouldn't be any thermal paste under there. it would be useless. Any chance you poked through the battery/tore it?
door
@oldturkey03 more than likely the inside of the battery
door
@tech_ni that is what I was thinking. The crumbling would make me think it is :-)
door
@oldturkey03 did know people still bought 5c, i binned about 8 housings with parts
door
@oldturkey03 won 2 items on ebay today for repair, iphone 8 no power for £8.50 and a gopro hero 8 for £17.50 with no power
door
21 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Could be the old adhesive. Seems to be in the right place. If the tabs break off I either use a heat mat and a spudger to gently lift the battery or put some alcohol down the side of the battery and tilt the phone so it runs over the adhesive.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
timtom77 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 499
