Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Vraag afgerond
Why my iPhone doesn't work?
My iPhone suddenly stops work when I was in looking a website by wifii. Since this, the display doesn't responde to touch.
Is dit een goede vraag?
1 Opmerking
I noticed you never got an answer to this. Are you still having this problem
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
First of all I'm assuming you tried doing a hard restart (Sleep/Wake button + Home button for 25 seconds). Plug it into your computer, create a backup, then restore from the backup. If this still doesn't work do a full restore without a backup.
I'm not sure what exactly happened to you (maybe a firmware bug or glitch) but this should fix it.
Good Luck!
-Brendon
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 840
