Ga door naar hoofdinhoud
Reparatiehandleidingen en demontage-informatie voor Android-telefoons in alle vormen, maten en kleuren. Vind hier alles wat je nodig hebt om je eigen telefoon te kunnen repareren.
79 Vragen Bekijk alle
Unlock bootloader of Android 11
Got 2 phones I'd like to unlock the bootloader and, eventually, flash /e/OS ...if possible. Problem; I've attempted using at least 3 different software programs and have had problems with/failures of all 3. (Magisk, KingRoot and KingoRoot) Someone "suggested" the manufacture locked the bootloader and, thus it cannot be unlocked. I don't agree with that(?) Yet, when Kingroot and Kingoroot were tried, neither would recognize these phones. Magisk had way to much add-ons to D/l for me. Just seemed too much for no more than what I was doing. So, I need some advice/help in unlocking the bootloaders...and can it be accomplished? #2. Can either/both be flashed to /e/OS? [Vortex v22-Android 11] [Sky EliteP55Max-Android 11GOedition] As you can see, my ultimate goal is de-goggling my phones....and life ...hopefully LOL P.S. Why so many dire warnings about unlocking a bootloader?
THANX
Rick
Is dit een goede vraag?
4 opmerkingen:
try going to settings\ about phone\ software information then repeatedly tap on build number until developer options are unlocked. then go to developer options just below about phone and look for an option called OEM unlocking. that should unlock your bootloader if your carrier hasn't disabled this. the Verizon phone i use has this disabled.
door
What is your phone?
door
@electronicsboy
The phones and models are listed in the original post
door
@zachariahorton
Thank you for replying. Yes, I understand your reply and have implemented those procedures awhile ago. Even with those "options" implemented, neither KingRoot nor KingORoot would 'recognize" the phone(s). What I'm unable to discover is whether the manufacture has locked the bootloader and/or even if that matters?
door
Voeg een opmerking toe
1 Antwoord
I recommend trying this: How to unlock the bootloader of an Android Phone
Was dit antwoord nuttig?
2 opmerkingen:
RE: ElectronicsBoy
Yes, I read/went through this prior to my posting. Because the "how-to" didn't provide unlocking the bootloader, I came here in search of an answer.
door
I found this on Google, you can try it: https://mobilewithdrivers.com/download/u...
door
Voeg je antwoord toe
Rick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 522
