Ga door naar hoofdinhoud
Looking for a source for replacement batteries?
Where Can I source replacement batteries?
Is dit een goede vraag?
4 opmerkingen
Bruce Lotimer yours is a Black and Decker BDH9600CHV? Just making sure.
door
Thanks for the reply. A project for this week.
door
== Replacement batteries for BDH9600CHV? ==
door
@tony88169 batteries are no longer available. You have to build your own.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Bruce Lotimer it seems like nobody makes or sells those anymore. Surprise right? Again lots of Dustbusters out there that get thrown away because parts are not available. Anyhow. Are you handy? You can actually create your own battery pack and it is not rocket science and not as scary as it sounds. Pretty much the same idea as on here Black and Decker 9074 schroevendraaierbatterij repareren All we would need to know, is what numbers your Ni-Cad battery cells show. You can post pictures of your battery with your Question. That way we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag Use this guide to at least get to the battery Black and Decker BDH9600CHV motor vervangen
If you are not handy, see if you have some handy friends or relatives that will do it for you. Does not take long, not very expensive to build and it will keep your vacuum going. Let's keep stuff out of the landfill and our hard earned money in our pockets, not B&D shareholders. Remember that
Repair is War on Entropy
Black and Decker 9074 Type 4 Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Black and Decker BDH9600CHV Motor Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
30 minutes
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Bruce Lotimer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 500
