Ga door naar hoofdinhoud
Informatie over reparatie, demontage en probleemoplossing voor de Anker SoundCore 2, een draagbare Bluetooth-speaker met 12 W stereogeluid, Bluetooth 5 en IPX7-waterbestendigheid. Uitgebracht in januari 2017.
Anker Soundcore 2 Water damage
Hey I had a question.So i kind of dipped anker sound core 2 in water eithout the charging cover on and now it wont turn on.Can you Help what might be the problem here?What components to change as i dont have support for anker in my country
Is dit een goede vraag?
1 Opmerking
you will need to open it and look for signs of damage, post photos here so we can see if anything looks bad
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the speaker's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your speaker and then remove the battery as soon as possible from the speaker to minimize any further damage.
Then you need to dis-assemble the rest of the speaker and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the speaker might possibly work correctly again.
Here is the ifixit Anker SoundCore 2 guide that will help.
If this process seems too daunting, take your speaker to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
abdurreheembakir zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 34
Altijd: 1,500
