Oil leak top of machine
Chef Premier.
Oil has appear inside the top cover around/ below the drive from the gear box to the electric motor, near to the blender drive.
Is dit een goede vraag?
Chef Premier.
@dhpreece your mixer does not use oil. What you have going on here is that the grease in the gearbox separates to solids and liquid. it is that liquid that gets pushed through the gasket. Time to take it apart and replace the grease. There are difference in the gearbox etc. with the Kenwood mixers. If you can provide us with the model number of yours or attach some good pictures with your QUESTION. I would expect your Premier to be a KMCXXX
Essentially these guides Kenwood Chef: Vervanging van de planetaire versnellingsbak SER1018 (Nederlands) should work but you may have slight variances.
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Handleiding
Moeilijkheid:
Moeilijk
2 - 6 hours
Was dit antwoord nuttig?
Check the gasket as shown in the second photo, Step#3 of this guide:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 69
Altijd: 3,376
