Ga door naar hoofdinhoud
The Samsung UN55KS9000F 55-inch 4K SUHD TV is a flat panel 2160P TV. Released from Samsung in 2016. Model number: UN55KS9000FXZA.
Weird shadow and backlight bleed.
I got this cool samsung television for free from someone I know, thought it would be a cool little project for a new free TV. I opened it up from the back but I have no idea where to start. It has a kind of shadow trough the middle of the screen and what looks like a crack in the middle where the backlight bleeds as you can see on the picture.
Any recommendations or ideas are welcome. Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
If the TV model you selected is the same as what you have, then it may be that one of the backlight LED strips (or power supply to the strip) is faulty.
Here's a supplier which shows images of the backlight strips.
The TV has edge lit backlighting (scroll down to Edge Lit) so perhaps the power to one of the strips is the problem, although the "crack" does seem a bit strange - maybe it's just a shadow effect from the failed backlight or perhaps a crack in the diffuser sheet
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
Cool, thanks!
And what about the crack?
door
@Ferre Vekemans
I don't know.
You will have to disassemble the display panel to see what the problem is.
You've got to do this anyway if the LED backlight strip needs replacing.
door
Alright thanks!
door
I have this issue with a Samsung MU7000. I spoke with a TV repair shop technician and he told me the LED guides deform over time because of heat and this causes the weird white triangles to appear on the bottom. He said the guides are built into the panel and the whole panel has to be replaced. Replacing the edge LEDs will not fix the problem and make it more noticeable.
To prevent this from happening, it is recommended not to run the TV at 100% brightness. A brightness setting of 30-70% will reduce heat. OLED screens do not have this issue.
Fortunately, these weird artifacts are not noticeable with darker images.
door
Voeg je antwoord toe
Ferre Vekemans zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 59
Altijd: 2,222
