Ga door naar hoofdinhoud
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
Rear passenger taillight won't function on turn signal or brake
I've already checked fuses, bulbs, even swapped resistors since I'm running LEDs . Other side works fine ...even connected them directly to the resistor but same outcome. Also checked connections with a volt meter and everything seems good ...is there something I missed?
Is dit een goede vraag?
1 Opmerking:
I think both replies are good and logical. Complete the circuit to ground.
door
Voeg een opmerking toe
3 Antwoorden
Hi @rreyes13
You said "Also checked connections with a volt meter and everything seems good..." I assume this means that there is voltage right up to the turn signal/stop light LED inputs in the lamp assembly is this correct?
If so have you checked the earth connection to the lamp assembly with an Ohmmeter or connecting a lead from the chassis (good clean bright shiny metal earth point) to the earth connection of the lamp module to see if they then worked OK? No earth = no current flow through the LEDs to light them up when voltage is applied.
Was dit antwoord nuttig?
Often what happens is that the common wire (the 'Earth ' or negative wire) which is common to many items in a car and usually connected to the car's chassis, does not make proper contact because of dirt, loose connection or rust. And even though you can obtain a voltage reading, under load and drawing current, the 'rusty' connection may present such a large resistance that there is just not enough current to drive the item under question. Note that a 50W car lamp can easily draw 4A plus and even though LEDs draw small currents, they are used in large numbers and are of the hi- bri type needing 20-50/70mA each.
Thus, try cleaning/removing rust, dirt & grease from connections associated with the item, then solidly tighten the connection(s).
Sounds like you have a ground problem on that light housing. Try running a jump wire from a known good ground to your socket or housing, if it lights up then you found your problem. Also does the truck have a trailer light plug? Those can be the source of many rear light problems as well.
Voeg je antwoord toe
Rey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 147
