Ga door naar hoofdinhoud
Braun MGK3060 8-in-1 Face & Head Precision trimming kit
charging pins are corroded
the charging pins corroded, on both the device and the charging base are they replaceable?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@waltwlms they might be replaceable but are definitely not readily available. I would start by cleaning those with some distilled water/vinegar 50/50 mix and a couple of cotton swabs. Since those contacts are most likely nickel plated, the corrosion destroyed teh nickel plating. It is most certainly tedious since there is not a lot of room. Once the corrosion is removed, clean any residue with distilled water and cotton swab only. Apply a small amount of grease or some stuff that is called NO_OX_ID (not cheap and you would only need a very small amount so that could be overkill unless it is available to you) After that make sure that your charging base stay relatively dry.
Was dit antwoord nuttig?
Voeg je antwoord toe
walt williams zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 263
