Ga door naar hoofdinhoud
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 Vragen Bekijk alle
My pc chrashes every week in between.
Hey. So i have had this pc for around a year and this has been a common issue now. My pc chashes every once a week and when it crashes i need to unplug my graphics card and plug inte in again after around 10 minutes for the pc to work again. And then after a week it does the same. I have checked overheating which shouldnt be an issue. Basically what happens is that the screen goes wide black and everything crashes but the pc still running.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The software or work you are doing on your PC is not capable to handle your card. It is my personal opinion. Might possible your card is old and not enough to work with the latest updates on your software or games whatever you are using. It is also possible that at some point may crash your display because all other time it is working. It should not work any time if there is a card or PC issue.
One thing you cantry simply format your PC and try to check the problem still presists.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Lucas_86 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 49
