Ga door naar hoofdinhoud
Repair and troubleshooting information for the HP Envy x360 m6-w laptop computer.
9 Vragen Bekijk alle
Is it hard to change the screen on these?
I have slight water damage on the bottom right of the screen and it still works but the screen seems pixilated where it happened. I have put a screen on a lenovo before but I'm just worried about the touch screen element of the job.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Here’s the maintenance and service guide for the laptop.
Go to p.49 to view the necessary pre-requisite steps and then the procedure to remove the display assembly and then the LCD panel.
It appears that the display panel comes as a complete module comprising both the LCD panel and the touch panel and not as two separately removable panels.
On p.50 (also seen on p.19) you will find the spare part numbers for the available display panels. Search online using the appropriate part number only in the search box of your browser to find suppliers that suit you best. If you wish to verify that you’re ordering the correct one for your particular model, usually the part number can be found on the back of the panel somewhere.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Ardara . Ie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 194
