Ga door naar hoofdinhoud
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
20 Vragen Bekijk alle
Solid red light on console
Yesterday when we turn it on, it would turn off until a bit warm but today when we turned the Xbox on it is a solid red light. We removed the hard drive and inserted a memory card but that doesn't work, we took the Xbox apart and did a full clean and it still doing the same, removed the cables and put everything back but that is also not working. I have been living on google the whole day. Anyone got some advice that I have not tried yet?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
We know you get a red light on the console itself, what color is the light on the power brick? If it is red it is likely defective. If the power brick checks out okay, see if you can get a secondary error code out of the console. You should be able to do this by holding the controller sync button and then hitting the eject button. You can do this 4 times to get 4 numbers. One light illuminated is a 1, two lights is 2, 3 lights is 3, and 4 lights is 0.
Was dit antwoord nuttig?
Score 1
9 opmerkingen:
Hi Ben, I never knew the model 1439 gave error codes but the brick is yellow and when I tried the sync button with eject button, the control had 4 green lights flash and still red on the console but I don't know if I did it right ?‍♀️?‍♀️
door
@nikki24 Keep hitting that eject and sync combo until it goes back to just the red light. Should be 4 presses to get to the last light combination and the 5th should return to just the red dot. Each press will reveal a light combination. Let me know how many lights are illuminated after each press, should be between 1 and 4 each time.
door
0003 is what I got. I have zero clue what it means!
door
@armorben please tell me it is something small that can be easily repaired and won't cost more than buying a ps4 or a new Xbox!
door
@nikki24 Unfortunately that error is not good. 0003 (also known as E03) indicates that the APU in the console is not receiving power. It could be a bad mosfet or a cold solder joint under the APU, this was more common on the original models but still happened on the earlier S model consoles. Either way replacing it would likely be cheaper than fixing it. Sorry to give you the bad news.
door
4 commentaren meer tonen
The code I got was 0101
Score 1
Red light on power button
Yo, i didnt check on mine but i think mine is just the thermal paste or the cable of the optic drive that is not connected properly.
found this wiki article that explains the error codes
https://consolemods.org/wiki/Xbox_360:Er...
Voeg je antwoord toe
Nakita Brandford zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 93
Afgelopen 30 dagen: 301
Altijd: 13,026
