Ga door naar hoofdinhoud
The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
20 Vragen Bekijk alle
Thansmission locked in park.
2013 year. Gear shift will not come out of park. Transmission is locked up.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Problem may not be in your trans mission. I side the car near the brake pedal there is a sensor/switch the electronically actuates a lock on the gear shifter. Some vehicles will have a shift lock bypass button. You can google search where that button is located and or if it has a bypass for your particular year make and model.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
pauld zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 50
