Ga door naar hoofdinhoud
Het W123-chassis omvat de 240D, 300D, 300TD, 280E en diverse andere modellen Mercedes-coupés, sedans en stationwagens uit de modeljaren 1977 tot 1985.
Mercedes-Benz cooling system temperature
My Mercedes-Benz cooling system temperature decrease when I drive for a long time, nevertheless there is a thermostat in the system. The temperature is between 50 and 80 celisiou but it should be stable at 80. Are there any reasons for that
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Coolant thermostat failure or perhaps someone has removed it. It is easy to remove and observe thermostat behavior in a pan of heated water on a cooking surface. These devices can come apart eventually due to corrosion and normal wear.
Was dit antwoord nuttig?
Score 4
@mohammedmerc check your temperature sensor to the gauge to make sure that your temperature truly decreases with longer drives. We would need to know the exact year and model of your MB to try and help you further.
Score 3
1 Opmerking:
My Mercedes-Benz is 1978
door
Voeg je antwoord toe
mohammed elsharkawy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 374
