Ga door naar hoofdinhoud
Acer Aspire V5-473P-5602 is a 14" Full HD touchscreen notebook originally manufactured in 2014.
1 Vragen Bekijk alle
I need a base case for acer aspire v5 473
Where can I purchase a case base for this model?
Is dit een goede vraag?
Score 1
2 opmerkingen:
Which country are you in... look for eBay
door
Yes, I’ve been searching EBay no luck Thank you
door
Voeg een opmerking toe
1 Antwoord
Hi @jsmalls24 ,
Do you have the old base case still?
There are a lot of base cases available for a V5 471 and V5 472 models which appear to use the same case, going by the part number.
If you have the old case still, check if there is a part number on it somewhere and then search online using the part number rather than the laptop model number.
It may be that it is the same case that is used for a different model but it is not listed for your model by the seller.
Just a thought.
Was dit antwoord nuttig?
2 opmerkingen:
Thank you, I will check into that
door
I'm having the same issue. Did you have any luck with the 471/472?
door
Voeg je antwoord toe
jeremy Smalls zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 313
