Ga door naar hoofdinhoud
The Epson Stylus NX415 is a color inkjet printer. The printer uses T088/69/68 ink cartridges, which use a wetness sensor behind the visible primary chip.
4 Vragen Bekijk alle
Error message displayed on printer.
The following error message is displayed on the printer. “ a printer error has occured. Then off the prjnter, then press On button to turn on. See your documentation. “ When this is done the error message is still there, even after unplugging the power and the line to the
Is dit een goede vraag?
2 opmerkingen:
Please tell us the full error message and code if it had one.
door
It just says error turn off and then on. It didn’t do anything
door
Voeg een opmerking toe
1 Antwoord
  1. Turn off the printer using the Power button.
  2. Use a pin to press and hold the Reset button at the back of the printer.
  3. Turn on the printer but keep the Reset button pressed for at least 5 seconds.
  4. Release the Reset button after a warning page is printed. After a few seconds, another page with the default IP address of the printer will be printed.
  5. Use this IP address to reconfigure the printer to the computer system.
Was dit antwoord nuttig?
Voeg je antwoord toe
Robert Passanisi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 149
