Ga door naar hoofdinhoud
Repair and troubleshooting information for the HP Pavilion dv6000, an HP laptop part of the HP Pavilion series. Released in April 2007.
Battery is stuck in laptop.
How can I remove the battery to check if it has been recalled.
Is dit een goede vraag?
Score 1
1 Opmerking
How is the cover stuck? Can you post a picture?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
To remove the battery move the battery hold latch to the right and tilt the battery out. See attached pic :-) be careful when you pry with anything, so as in not to break the housing etc. To check the eligibility for the battery recall check on this website it will give you the proper procedure and numbers. Good Luck.
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
make sure you unlock the clips first
if they are in right position just turn laptop upside down or help with a knife or something
door
heyy thnx for the response but it seems like the battery latch is stuck and not moving
door
i have the same problem on my dv7
door
what if the latch is broken
Voeg je antwoord toe
Donna Durand zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 5,273
