Ga door naar hoofdinhoud
The iMac G3 came in tangerine, blueberry, lime, grape, and strawberry colors.
16 Vragen Bekijk alle
How do I install the MacOs?
Change the original 4GB HDD of this model to an 80GB one. But I can't install the system to use it again. I light it and the “?” Icon is flashing. Download and burn discs with MacOs 9, 8 and I can't make it boot from the CD. As I read it was to keep the letter "c" after the ignition but does nothing. I would greatly appreciate your help.
Is dit een goede vraag?
Score 1
1 Opmerking
What is the make and model of the drive you installed?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Partition the drive with one 8GB partition, and one 72GB Partition onto your IDE drive (do not use a SATA drive). Install the system onto the 8GB partition.
iMac G3 Model M4984 Hard Drive Replacement
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Horacio aparo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 151
