Ga door naar hoofdinhoud
A series of 40 inch LCD HDTVs by Sony.
20 Vragen Bekijk alle
6 red blinks and nothing
Hello,
I have five years old Sony Bravia KDL-40W600B. Two months ago my TV broke down with the 6 blinks symptom. I browsed the internet for some solution and finally ordered via eBay Sony A-1983-521-A LD Board and replaced it. Everything was fine until yesterday when my TV broke down again with the 6 blinks symptom. Please advise me what to do?
Thank you in advance,
Vadim
Update (01/21/2020)
There is one very interesting thing. When I bought a replacement board the back side of it was green all around. Now I see it's discolored under one of capacitor like on old board. Maybe this fact can help to trace up an issue.
Thanks,
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@loravadim this could have been caused by a lesser quality replacement board. There is always a possibility that your LED backlights are causing this but at this time I would go ahead and replace it once more . I’d consider a different source for that board. Let us know if the new board resolved this issues.
Was dit antwoord nuttig?
Score 1
15 opmerkingen:
Thanks,
door
@loravadim it is one of the IC's that overheated. If you can get a couple clearer picture we might identify the type and model of it and determine if this is a common failure. It is possible that this is one of those boards that is "meant" to fail after a while by using substandard parts.
door
@loravadim identified the IC as a BD9397EFV LED driver. Yours obviously failed and possibly because of an overvoltage
door
Thank you. What is a possible solution? What do I need to replace? Thank you again.
door
A replacement board is less expensive than to get it repaired. I wonder if your board just gets to many power spikes. You may consider a surge protector and give that a try. Again, it may just have been a substandard board.
door
10 commentaren meer tonen
Voeg je antwoord toe
Lora Fomina zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 1,350
