Ga door naar hoofdinhoud
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
20 Vragen Bekijk alle
iPad 2 wont connect to open WiFi network
When i try to connect my iPad 2 to the guest WiFi at my school, it just has the loading circle and wont connect, however it will connect to my home WiFi perfectly fine showing the little check mark. i have tried factory resetting the internet options and it did not work.
Update (01/16/2020)
PROBLEM SOLVED!!! After a quick factory reset on the iPad it will connect to my schools WiFi
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Have you tried opening a browser? Usually with these cases you are required to login some other way besides using just the Wifi password, especially at a school. Check with your front office, they probably have the login information (unless it's not actually a guest account for students, in which case you're probably out of luck by normal means)
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
i have tried opening both chrome and safari, and going to an HTTP website such as www.cnn.com but it doesnt redirect to the internet login page
door
i have also used this guest WiFi perfectly fine on other devices such as my phone, and the school uses it on some of their computers aswell
door
Voeg je antwoord toe
Vipaha zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 101
