Ga door naar hoofdinhoud
Unresponsive sleep button with slight water damage
My sleep button started failing after i touched my ipod touch with really wet hands and probably got little bit of water into it. The ipod started going on and off with the screen which i just proceeded to shut it down and put it in a bag of rice to remove the water and moisture from it. The sleep button works but after i press it like 50 times which is fine but i've been putting up with this problem for like 5 months and i'm wondering is there a way to repair this?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes. The ipod touch screen needs to be removed as well as everything else including the lcd and mother board along with the wifi cable which lies above the sleep button flex cable. Once everything is out you can access the sleep and volume buttons which are all one piece. Remove the four screws holding the buttons in place then life all adhesive and tape holding it to the backplate. Once done then just simply swap a new one in place and reassemble. You can purchase the parts off of ebay for about $10.00
Remember be careful and have soft hands so you dont break the lcd and touch screen which will throw your repair up another $30.00
Was dit antwoord nuttig?
1 Opmerking:
if you want to advertise your business, please don't do it on here. Put your website address in you profile.
door
Voeg je antwoord toe
Roy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 908
