Ga door naar hoofdinhoud
The Logitech G700s is a wireless gaming mouse that connects to a computer using a USB wireless receiver. The mouse has 12 programmable buttons, and has a DPI of 200-8200
2 Vragen Bekijk alle
I got a new mouse and it wont scroll
I changed the settings but it still wont work.
Is dit een goede vraag?
Score 1
1 Opmerking:
If you haven't already I would download the Logitech software associated with the G700 then check the key-binds on it. My Razer Naga had the same problem, but fixing the key-binds fixed it. If it doesn't work I would recommend contacting Logitech.
door
Voeg een opmerking toe
1 Antwoord
The scroll wheel rotates inside a transparent plastic piece. Remove and clean the transparent plastic piece with alcohol, both sides. The optical sensors infrared light needs to cross the two windows on the plastic piece and the wheel. If the plastic is dirty, the scroll wheel won't work. The dirt comes inside easy from the wheel. Make sure that the tiny slots inside the wheel are clean too, they look like bicycle wheel spokes.
Was dit antwoord nuttig?
Voeg je antwoord toe
rose simmer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 184
