The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
1 Opmerking:
Are you sure the volume is turned up? When was the last time the sound was working? Did you make any changes to the 2DS before the sound stopped working? Did the 2DS get damaged or get wet before it stopped working. Can you hear the sound if you plug in some headphones?
Sorry for the delayed response, but I figured it out...I neglected to mention that I did go inside it to replace the tiny joystick, and I inadvertently hit the volume switch from the inside. But thank you for taking the time to respond.
door Joshua Freeman
