Ga door naar hoofdinhoud
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
20 Vragen Bekijk alle
Why do I have no sound?
no sound coming from speaker
Is dit een goede vraag?
1 Opmerking:
Are you sure the volume is turned up? When was the last time the sound was working? Did you make any changes to the 2DS before the sound stopped working? Did the 2DS get damaged or get wet before it stopped working. Can you hear the sound if you plug in some headphones?
door
Voeg een opmerking toe
1 Antwoord
Sorry for the delayed response, but I figured it out...I neglected to mention that I did go inside it to replace the tiny joystick, and I inadvertently hit the volume switch from the inside. But thank you for taking the time to respond.
Was dit antwoord nuttig?
Voeg je antwoord toe
LDMonty zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 230
