Ga door naar hoofdinhoud
At the 2004 North American International Auto Show, Nissan unveiled a completely redesigned Pathfinder for the 2005 model year.
14 Vragen Bekijk alle
Help no brake lights but tail lights work
I have no brake lights but my tail lights work. I recently had a trailer brake installed in my 2008 Nissan Pathfinder. I don't know if this could be a cause of my problem. Any ideas? We have checked fuses and wires all seem to be good.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sara Allread, could be a bad brake light switch.
Remove the contact from the switch and apply a small jumper between the pins on your cable. If the stop lights come on you know it’s a bad switch. There are really not a lot of other things in this circuit that would cause it.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sara Allred zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 990
