Ga door naar hoofdinhoud
The LG X Power is a 4G LTE smart phone that was released on August 2016. This model has a 16 GB memory with an Android operating system.
20 Vragen Bekijk alle
battery sign with a question mark in it
When i plug in my phone to charge im just getting a battery sign with a question mark in the middle of it? what does that mean?
Is dit een goede vraag?
Score 12
13 opmerkingen
My lg q6 alpha is showing the red question sign on the screen I don't what to do
door
What do I need too do if my phone want come on and only show a ? Mark
door
my lg is not turning on
door
I have a lg Stylo phone that I replaced the charging port in which was fairly easy. After getting the phone back together I plugged it in and all it will do is flash the battery sign with a question mark in the middle of it. How do I fix this?
door
I have the same problem in my lg v10 question mark after connecting the charger
door
8 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Try a different cable, and charger transformer (plug into pc to charge. A question mark I've seen to be a few different things. Dust in phone charge port, battery took a crap. Or bad charger/transformer
  1. Clean charge port. And cable connection
  2. Replace charger/cable
  3. Replace battery/charge port
Was dit antwoord nuttig?
Score 5
5 opmerkingen:
OK thank you
door
Hold finger on Questiomark for while..
door
still not working..... im getting mad
door
1 ; either try cleaning battery
2 ; let your phone get cool
3 ; idk
door
If your lg k20 gives you a battery with a red question mark in it 😭😭😭 do a replacement with the battery my grandma's worker at work named Sam said it needs a new battery even with a 2 boxes one with the lg and one with a red question mark ❓ that
door
If u can't turn on the phone after a few seconds of holding down the power button, and the ? Battery when appears don’t disappear when plugging it in. Its probably either the charger or ur phone got overheated where it needs time to cool down for a bit. Once ur able to turn it on by the power cord then its fine. Just keep it out of intense heated places and keep it cool.
Score 2
2 opmerkingen:
If you get anew battery note to remove the stick on the 4 battery connectors
door
im getting the red question mark. i just installed a new battery. please clarify "remove the stick" on the battery connectors. thanks
door
Voeg je antwoord toe
Jonathan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 208
Altijd: 55,878
