Ga door naar hoofdinhoud
The 2009 Murano made its public debut at the 2007 Los Angeles Auto Show in November and sales began in early January 2008.
8 Vragen Bekijk alle
What is cause of white smoke at start up
Murano has a lot of white smoke at startup
but then burns off and runs fine. Thought head gasket but coolant level is normal and oil is normal color. Did engine oil flush and replaced pcv. No check engine light. Ony has 51k miles.
Is dit een goede vraag?
1 Opmerking
I am having the same problem with my 2014 Nissan Murano s model. Huge plume of white smoke on start up the. Goes away. I am getting a P0011 code. I changed the PCV valve today and the smoke still happened. There is sludge in the oil and not sure why because I have done regular oil changes since purchase with synthetic oil. I’m am not really sure where to go from here.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
White smoke can be nothing to be concerned about if it's thin, like vapor. ... However, thicker smoke is a big problem, and can be caused the engine burning coolant. This can be the result of a serious issue like a blown head gasket, a damaged cylinder head, or a cracked engine block – all of which are costly repairs.
Was dit antwoord nuttig?
Score 3
Hi @lazylane77,
I don't know the answer but this may be of some help.
Here’s the 2014 Nissan Murano Repair Manual (SM14E00Z51U0) that may also be of some help. The Engine Control System deals with the Intake Valve Timing Control. The Engine Mechanical section deals with the timing chain and the camshaft.
Hopefully a start
Voeg je antwoord toe
S Hassell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 24
Altijd: 2,943
