Ga door naar hoofdinhoud
The sixth generation Maxima, code-named A34, was only sold in the United States, Canada and Mexico. It was introduced in production form as a 2004 model at the 2003 North American International Auto Show.
20 Vragen Bekijk alle
My brake light on dash stays on
Parking brake switch, brake light on dash stays on
Is dit een goede vraag?
2 opmerkingen
You could bring it to the nearest Mechanic shop and get it fixed there.
door
Had all that fixed and it’s still on
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @pissingmeoff ,
The “brake” indicator light in the dash has two functions.
It indicates that the parking brake is applied and it is also a low brake fluid level warning light.
If the light is on with the ignition on but the parking brake is released then first check the brake fluid reservoir to ensure that the brake fluid level is correct.
If it is OK then perhaps there may be a faulty sensor in the reservoir or the parking brake switch may be faulty
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Robert Lewis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 41
Altijd: 3,488
