Ga door naar hoofdinhoud
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Pins for speaker on logic board are missing
I was repairing the speakers but noticed, the speakers had already been tampered with, o found out that the speaker was broken and the pins on the logic board were missing. Where can I get a replacement for that? I figure I'll be soldering it on and I'm thinking about ordering the part from Digikey but I am unsure of the part number.
Is dit een goede vraag?
2 opmerkingen
Just to be clear, you need a new speaker assembly?
door
No, I already got the assembly, but there is literally nothing on the logic board for it to connect to, as if the socket was ripped out when it was tampered with in the past
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Take a look at the picture of Step 37 of this guide.
The wire bundle and connector on the speaker plug into a receptacle on the logic board. If that receptacle is no longer on the logic board, then you will need to have a micro-solderer replace it so that you can use the speaker again.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
I know that it would need to be soldered on, but what is the part needed? I really just need a model number to purchase the part
door
Sorry, I missed that. It's pretty easy to source, check out this page:(https://www.google.com/search?hl=en&q=ip...). I don't know the exact model number so it would be hard to find on DIgiKey...they literally have hundreds of thousands of connector models to choose from.
door
Thank you so much!
door
Voeg je antwoord toe
rebekah Luper zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 67
