Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Ipad mini 2 - Wont turn on
Hello there,
i am having issues with an iPad mini 2. When i turn it on i can see the apple logo for a second and than the lcd turns off. When i plug it into my Computer it says it is running just fine, but i cant see a thing on the Screen.
I did a hard and soft reset and after that i restored it. Still the same thing.
Is it a more likely a Software or a Hardware Problem. Do you have any suggestions how to fixit?
Thank you guys Peace Üt
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Once the screen goes dark, push the home button and shine a bright flashlight on the screen. If you see a dim image, then the problem is backlight related. If you see no image at all, then you have an LCD issue. It's hard to say if its related to the actual LCD itself (which also includes the backlight) or with the driver circuits on the logic board.
Has anything out of the ordinary happened to the iPad recently, such as drops, damage, repairs or contact with water?
At some point, it will have to be opened up for proper troubleshooting.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Niklas Jakob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 354
