Ga door naar hoofdinhoud
An E-reader released by Amazon.com on April 27th 2016. The model number is SW56RW.
18 Vragen Bekijk alle
My Kindle Oasis fell into the water. Can you repair it?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@goodharbor122 we can't fix it for you. We are volunteers that help others to fix their own devices. In the case of your Kindle, I recommend that you totally disassemble it using these guides Amazon Kindle Oasis 8th Gen Motherboard Replacement Then clean every part with some 90%+ isopropyl alcohol. That includes the cables, connectors etc. Use something like this guide Repairing iPhone Liquid Damage to see how to clean a device. The guide was written for an iPhone but the same pretty much applies to any device. After you clean it and have it dried, replace the battery and then reassemble. Only then can you evaluate your Kindle for any other damage.
iPhone Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
1 - 2 hours
Amazon Kindle Oasis (8th Gen) Motherboard Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
20 minutes
Was dit antwoord nuttig?
Score 4
you will need to take it to a local repair shop as this site is to help people, not for repair service
Score 2
Voeg je antwoord toe
Loretta Ligor zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 570
