Inleiding
The motherboard holds together all the main components for the Kindle. Without a motherboard, your Kindle will not function. With a defective motherboard, your Kindle will run into some problems. This guide will teach you how to change your Kindle's motherboard.
Wat je nodig hebt
Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
Attach the new battery by inserting the end of the orange power connector (the end not attached to the battery) clips into a little socket on the device (it's barely visible). You can tell when it clips in by the feel and sound. Make sure that when you put the new battery in, you first clip the connector in before you stick the tape down.
Be Aware: Your new battery might not be charged, so it may not power-on immediately! After replacing the battery, plug your Oasis in and let the battery charge to full capacity.
Locate the 2 Phillips screws (labeled PH 0) and remove screws using a screwdriver with a PH0 bit.
Locate the 3 Phillips screws (PH 0) on the motherboard and proceed to unscrew them using a screwdriver with a PH 0 bit.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Hola tendrá es placa base que necesito una pieza. Para ver si lo puedo reparar?
