Ga door naar hoofdinhoud
Released in 2012, the Asus N56VZ is a 15-inch laptop with a screen resolution of 1920x1080 pixels. It has an Intel Core i7 and an Nvidia graphics card inside.
12 Vragen Bekijk alle
bluetooth file can't transfer from laptop to handphone
bluetooth device not work
Is dit een goede vraag?
1 Opmerking
sean2077 what make and model phone is it?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Bluetooth isn't the best method for transferring files from your PC to phone. It's unreliable, slow and most times doesn't work. The best method is to use cloud software (i.e. Upload to google drive and download on your phone) or use a cable. If you have an android phone, simply connect your phone to your PC, enable file transfer from the "USB for charging" option, and drag any files from your PC to the "Download" folder of your phone. If you have an iPhone, connect it to your PC/Mac and use iTunes to transfer the files.
If you really want to use Bluetooth you'll have to provide us with more details.
Hope this helps!
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Depending on the phone many offer USB connection which is what I would use or WiFi.
door
Voeg je antwoord toe
sean2077 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 360
