Ga door naar hoofdinhoud
Uitgebracht in maart 2016, 7,0" Galaxy-tablet van Samsung.
Weird lines on Android tablet galaxy
Afbeelding
Afbeelding
My Android tablet has weird lines on the screen. It’s not that bad but it’s annoying. It happened right after it was 15%. Should I bring it to a repair man or is it better if I fix it myself?
Thanks,
Krakendogeyt
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It's probably the graphics processor unit. From what I can tell in the image the lines are not on top of the HUD items in the game, which is software or hardware failure.
If you haven't restarted the tablet yet, do so now by holding the power button until the option to restart or shutdown pops up. If that didn't fix it, try a factory reset. This will wipe all data on the tablet and restore it to factory settings. Backup all of your important data to your PC then use the factory reset option in settings under "Backup & Reset settings".
Last of all, the problem wasn't fixed by that, than the problem must be hardware rather than software. IF you purchased it within the last year, than it should still be under warranty. Contact Samsung Warranty claim to get your tablet repaired by samsung for free. But if you aren't still covered by warranty, you will have to do it yourself. USe this guide to replace your motherboard: Samsung Galaxy Tab 4 7.0 moederbord vervangen
(There is no guide for your specific tablet, but this one is a very similar model.)
Hope this helps!
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
@dsc229088 that will depend on what it is. Could be the display itself or it could be a connector/circuitboard issue. You do want to post a picture of what your screen shows. Post that with your question so that we can see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that. you can use these guides Samsung Galaxy Tab A 7.0 to at least get into the tablet. "bring it to a repair man or is it better if I fix it myself" only you know your skills and abilities. If you feel comfortable working on it, there is no reason not do so.
Score 3
Voeg je antwoord toe
Krakendogeyt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 116
Altijd: 35,714
