iPhone 6s Searching/No Service
I have an iPhone 6s that has the searching/no service issue. I've seen this a lot online with the iPhone 6/6 Plus, but no one really talks about it with the 6s. Is it caused by the same baseband ic issue or is it another chip? I've looked around to get this repaired, but no one really seems to offer this service. Does anyone know where I can get this chip reballed? Thanks in advanced!
Is dit een goede vraag?
6 opmerkingen
I had this problem after replacing the screen. I took the cellular antenna out (see youtube for videos) and cleaned using an alcohol screen cleaner (polaroid) and wiped with screen/glasses cloth. Put the antenna back in place and re-connected the battery and hey presto, problem solved. I was using the method of rolling the screen across my leg, which worked for a while. Also, I think warming the phone up helped as well, but cleaning the area where the cellular antenna is seated helped and got the iphone working.
door Kerrie Blennerhassett
https://www.youtube.com/watch?v=bSjJnFaU...
This is the solution, i tried every thing,about 1 week, no way to take back the signal, and this $@$* really worked
door Adi Adrian
The video is unavailable...Can you please suggest another video?
door jahanggir15-10533
https://youtu.be/7JvjR3WC37A New link to similar video
door Brian J
Thanks very much, man...I appreciate your help...
1 commentaar meer tonen
